Go Pro Movies
Discussion in 'Lounge' started by pingping010101, May 29, 2014.
  1. Here's my first bash at making a video using the go pro. Needs work, also I need to stop being a rubbish rider! Also, the quality is low so I could get something uploaded quickly.
  2. yep i agree..............
  3. Don't work
  4. Does now, music goes with the bike :Asshat:
  5. Showing a little to much of the clocks?
  6. Good point. Removed.
  7. DOH..... Just sat down with the popcorn and its not showing.....
  8. Nothing to see here... Move along...
  9. :Mooning:
  10. It's been removed :/
  11. If you need some hints etc, pm @andyp79, he's got well into filming his rides. He also posts them up on his motorcycle diaries webbyblogthing which is worth a visit too :)
  12. I'll have another go at the weekend.
  13. I've had another go, the footage itself is a bit tame and the whole thing is amateurish, but its a first attempt.
    Final Cut Pro is brilliant to use, but I only got a 30 day free trial and I think the software is around 10 bazzillion pounds if you want to buy a copy.
  14. Looks good enough to me. Liking the different angles and transitions plus its not a long tedious video.
  15. That's really good. The ones looking back at you are at a good angle.
    Posser ;)
  16. I bought the gopro stick mount and fitted it to the mirror stem. Need to find a decent bit of road with some strong corners to get decent shots with that angle.
    I used that road because it's quiet and tucked away on salisbury plain and I wouldn't cause a drama riding up and down the same stretch 10 times. The side fairing was too flimsy and I couldn't use most of those shots due to excessive judder. Will need to find a way to mount to the frame or something less prone to flex.
    #17 pingping010101, Jun 7, 2014
  17. Yeh great road. You need a mic to tell everyone about you day, thoughts and how to change the world.
  18. You know, you don't have to watch it, nor criticise me for making it!
  19. Not really sure if that's directed at me. If so, there was no offence intended. I was joking about the mic, it happens. And, it is a nice road.
