1200 DVT Handguard Removal?
Discussion in 'Multistrada' started by pjsixty2, Jun 18, 2020.
  1. #1 pjsixty2, Jun 18, 2020
  2. You are aware that the thread on one of the mirrors is the opposite of normal?
  3. Hi, yes, aka Yamaha style. Supplier of that particular mirror assures me they are - but they look a bit cheap
  4. I swapped the hand guards and mirrors on my original 2010 multi. Ducati used to make mirrors with indicators in the tips and much more substantial harder plastic hand guards.
    I swapped because I commuted into London and broke about three of the standard hand guards when you had to replace the whole unit.
    I bought mine secondhand but looks like they might still available.
    http://www.ducati-performance.net/epages/61572090.mobile/en_GB/ObjectPath=/Shops/61572090/Products/%2296796810B/+96796910B%22&Locale=en_GB
    https://www.ebay.co.uk/p/1636756693...2Kd0RKNpBjOfvjYSpty2R6MDpCmwss-EaApq5EALw_wcB
  5. Ps these were much more Substantial!
  6. Thanks for that - hadn't seen those guards. And I'm guessing the guards also don't stick out so wide each side? I''d hoped to lose the guards altogether but I think that would involve having new brackets fabricated for the reservoirs?
  7. I can’t quite remember the fitting of the reservoirs. I know you can get small metal brackets for the Monster and Streetfighter which might fit. I think they were probably larger and stuck out as far.
    The advantage of these guards is how robust they were, much more like a BMW GS item, strong with some flexibility and they looped round to the end of the handlebars, much better than the 1st generation ones.
    I really don’t understand why Ducati don’t redesign the handguards to make them stronger. I guess they sell a lot of spares!
  8. Thanks - yep agree. Aesthetcally, I like them - they are just going to get snarled up in (spirited albeit only occcasional) london filtering!
    Those brackets could get me back in the game - cheers for that. I've also just found a pair of those nicer mirrors you mentioned on ebay. Just before I make an offer on them, do you have the same ones on a 2015 - 2017 multi? And the electrics and fitment work?
  9. I didn’t fit them to the newer Multi’s but I can’t see why they wouldn't fit and connect with the wiring.
    The only thing I found was the mirror was a bit smaller and not quite such a good view. They were still ok for me but might be worth considering in London traffic.
    #9 Twin4me, Jun 19, 2020
  10. Thanks. Sorry I re read your post - yes I had 2010 multi too but cant recall it being so wide. I assume you meant 'I can't see why they wouldn't fit and connect?' re the mirrors?
  11. sorry, autocorrect!
  12. Thanks for your posts - mirrors and brackets ordered!
