Has Anyone Used A Kriega Tailpack On A Supersport?
Discussion in 'Supersport (2016 onwards)' started by wastegate, Sep 29, 2020.
  1. The 4 straps that go under the seat need somewhere to hook into so would be interested if anyone has used one. Cheers
  2. Yes. There are four straps under the seat to strap the Kriega to. You should look.
  3. Will do when I get one, this means I don't have to budget for yet another luggage system, cheers.
  4. I used my US20 on the back of the Supersport 939 many time. ust used the loops under the saddle. Cracking bit of kit.
  5. Thanks David. That's what I currently use so good to hear it will work if I swap to the Supersport. It means I don't have to add to the pile of luggage types & systems in the loft which promised much but often only seemed to work well some of the time.
  6. I've used the Kriega US system on my Panigale 959. I managed to screw in the "holding straps" under the rear seat pad as you can see from the pics below. It worked a treat. :)
  7. I've been using a Kriega US20 pack on my Supersport for the last 3 years. Originally I used the supplied strap anchor points attached to the bottom of the seat. However, wasn't happy with the way the straps pulled the seat away from the frame when they were tensioned, especially at the rear at the tail light, nor the fact that the pack was only attached to the seat. So I made some additional cordura strap anchor points fixed to the screws securing the side panels below the seat. The Kriega pack now sits securely attached to the frame, pulling the seat down not up.
    #7 Derek, Sep 30, 2020
  8. I have a set of ST2 panniers and a quick release mounting frame on my Supersport, works great.
  9. LaraMoto does a review of the Supersport S here and also discusses Kreiga tailpack
  10. Quite like them supersports in white
