Does the standard 749 2003 vintage have the adjustable steering head angle ? Has anyone got a suspension set up for a 13st bugger . just a base line ..high at back low at front stuff.
Im a bit heavier than you and do 2up on a 999. I dropped the forks to 4 rings showing(max), rear ride height 285mm centres as per brad the bikeboy stge1. I use factory settings on preload, comp and rebound.
