950 Healtech Exhaust Servo
Discussion in 'Multistrada' started by Martin Newman, Aug 5, 2024.
  1. Hi , having sold my 2021 950s Multistrada , when I reinstall the standard muffler do I have to remove also the Healtech exhaust servo/eliminator ? Or no harm just to leave in situ?
    Also If it's for a 950s can I also re-use on a Multi V4s or is it not that simple/compatible ?
    Many thanks
    #1 Martin Newman, Aug 5, 2024
  2. The Multi V4S (and other V4s) do not have an exhaust flap - thankfully :)
    You could leave it on the 950 no issues.
  3. If you leave it on you can be sure the bike will run ok and the valve won’t be stuck (hopefully)
  4. Thanks both, I looked into it a little more and it looks easy enough to remove, I could then sell it with the Arrow muffler
