Healtech Speedo Converter/healer
Discussion in 'Ducati General Discussion' started by bettes, Aug 16, 2018.
  1. right. Looks like getting the digital dash converted from KPH to MPH might take a bit more effort to get sorted...
    Thinking about trying a healtech speedohealer for the time being. Bike uses a 999 type speed sensor so should be doable.
    Anybody used one before?
    Ian
  2. What bike ?
    I'm sure the facility is there on digital dash to either read kmh or mph but just needs to be switched over. Not sure if this is through the ECU or the dash itself. ECU can be unlocked with tuneboy software.
  3. Thanks for that. Problem is it’s a one off dash, no instructions and have already tried most possible button combinations. Been in touch with a few electronic dash experts and they both said the same, that they would need the original software to reverse engineer the software. They also suggested that the quickest / easiest option would be to fit a speedohealer. The speed sensor used with this dash is a Bosch, 3 wire T9 jobby so should be a straight forward job to fit.
    It’s for a 998S with 996R ecu.
