Help starter problem
Discussion in 'Technical Help' started by alan, Apr 15, 2013.
  1. [h=2]Help starter problem[/h]
    I have a 1999 750SS and have just replaced the starter motor...now the starter motor spins but the engine does not..Does anyone have any ideas ??I am at the end of my tether [​IMG]
  2. Sounds like the sprag clutch is spinning freely, did you fit it the right way round?
  3. I removed the old starter motor and replaced with a new one
  4. Dont know if its the same with a bike starter but in a car the starter has a primary and secondary circuit, one spins up the starter and the other engages it into the flywheel.
    Not unheard of for new starters to be faulty, but would double check all electrical connections.
