Hm Plus Quickshifter
Discussion in 'Technical Help' started by scratch pervert, May 20, 2015.
  1. Spent the afternoon with @andyvtwin fitting the above to my 848 evo.
    Can't get into setup mode for some reason... Following the instructions and holding down button while turning ignition on, count down starts as it should but seems to stop when it gets to 3, instead of counting down to 0. Anyone got any thoughts on what could be the problem?
  2. In order to do this on a Panigale, the engine needs to be running. HM doesn't seem to get power without engine running.
    No idea if that's your problem on the 848 but worth a mention in case it is.
  3. I'm sure it's something to do with the ducatis going into the power saving mode when the ignition is switched on and you have to have the engine running to get into the set up mode.
  4. But holding the button down with engine running doesn't do anything...?
  5. Hold button down then ignition and turn the engine on
  6. It works... Thanks guys! (b)
