Looking at selling my trackbike as I may be upgrading. This is not your usual trackbike and has had a lot of money spent on it. Very well maintained, very light and very fast. Recently serviced by Dave Hewson from Obsession Engineering. I'll upload more photos at the weekend. Bike stand not part of the sale £7500 Spec is as follows: Chris Mehew engine. Kent Cams, worked head etc usual WSS spec. Engine opened and Valves and timing checked . Leakdown and compression test carried out (perfect). All work done in 2020 and done 7 trackdays since. HRC gearbox & hybrid ceramic bearings. New Sigma Slipper Clutch with new OEM honda clutch plates (not ridden since fitting) (Feb 2022). PTR manual Cam Chain Tensioner. Custom made thermostat housing. HRC Kit Loom. HRC Kit Dash Loom HRC ‘Ten Kate worked’ ECU and X bikes mapped including timing etc. Custom billet PTR WSS Velocity stacks. Ten Kate Racing Products lightweight clutch cable assembly. Full titanium Pro bolt engine kit GPR Race steering damper. Titanium valve cover bolts Pro bolt titanium magnetic sump plug. Pro bolt titanium oil filler cap. New NGK spark plugs. Full arrow race exhaust system - full carbon Indy with removable baffle. Pairs system removed and blanked with Mehew blanks. Mupo Factory K911 & evo racing suspension front and rear (with remote preload). (Last services by Dave Croft Aug 2020). Ten Kate Racing Products front subframe Ten Kate Racing Products air intake. MWR racing air filter Lightech chain adjusters Lightech Magnesium rear sets (race and road pattern) Kelfab lock stop savers. Healtec gear indicator. Translogic quick shifter (race shift) Race fairings with tall TT screen. Renthal clip ons Domino grips. TWM Brake Lever Guard Domino quick action throttle Aliant Lightweight lithium battery ACU Rain light (operated from its own switch) Gb racing engine protectors R&G acu shark fin chain guard R&G tank grips R&G bobbins Eazi Grip evo tank grips and tank protector. Renthal sprocket(s) and EK Gold chain 520. Titanium sprocket nuts. Titanium disc bolts front. Biketek Quick fill tank cap Motul RBS 660 fluid. Run on Motul 300v HEL Brake lines HRC reservoir HRC rear brake reservoir Accossato 19 master cylinder New EBC GPfax pads (Feb 2020) Full Samco hose kit New OEM radiator (original was showing signs of wear) (Feb 2022) Metzeller Track Day slicks (1 trackdays use) Spare Wheels with discs and brand new Pirelli wets Full set of spare fairings Motogp tyre warmers Spare rear sprockets Spare clutch levers V5 in my name
Hi Andy, Not at the moment no but i will check once my helper has returned from her trip to the supermarket!! For reference I have a massive 29" inside leg and i get both toes down! Also to note it's had the giant of man @Advikaz on it without issues!
Andy, it's between 805 and 810mm. I'm 5'7" and I'm very comfortable on it. Both balls of feet on the ground which is generally unheard of for me
Thank you very much for doing that. My partner is petite so for her, seat height comes before any of the jucy spec. Food for thought Andy
