749 How Do I Test My Tps?
Discussion in '749 / 999' started by bluey, Jan 15, 2016.
  1. Hi All
    I have my airbox in pieces as I want to test my TPS and maybe change it. I have some funny goings on with small throttle openings rarrrarr!! :)
    Anyways the airbox removal is easy isn't it!!
  2. BikeBoy.org - DucatiLinear Throttle Position Sensor setting notes for all models 08/08
    I used this page to help me reset the TPS from scratch. I have removed the airbox so I could gain access to the adjuster on the throttle cam so I could be sure it was adjusted correctly. Since I could find no guide to test the tps I wont know if this has worked until I rebuild an attempt a start up.
    I used GuzziDiag in the end as JPdiag kept freezing over and over. Guzzidiag is easy to use too.
