how heavy is your ass?.
Discussion in 'Technical Help' started by speno, May 10, 2013.
  1. as in a guess what a bottom end from a 748 is minus the covers/clutch might weigh?......just trying to work out the postage cost for,well,that bloke with the fucked 748 bottom end and stuff....cheers.speno.:upyeah:
    #1 speno, May 10, 2013
  2. thats what i did with the wife after she fooked the scales.
  3. I sent an ST2 bottom end (which is basically the same as a 748) by courier to Ireland, but it was minus the side casings, flywheel, alternator, starter motor, sprag, clutch, oil pump etc. so basically just the crankcases and the 'stuff' inside them. IIRC it weighed around 35kg packed in a big cardboard box with plenty of soft packaging.
  4. thanks mate.:upyeah:
  6. Try Parcel Monkey for a quote. :upyeah:
    PS. You taking a trade in...? :wink:
  7. You might be better sending it via a motorcycle courier. At least it's a flat rate and you know it'll be handled by people that know what it is
