I am considering doing a track day on my 97 916 which is mostly standard apart from the termignoni "silencers" Anyone know who loud this is likely to be? And if standard exhaust fitted? Cheers
What sort of Termis do you have? 45 half system/45-50 half system/full 50 or above? Also, where are you going and what is the limit? My 916SPS with full 50 system never needed baffles.
I’ve got a full 50mm system, an it’s 101db Only place I struggle with is the quiet days at donny (98db) and castle Combe due to how they noise test, they are 105db at 3/4 rpm so it’s about 8k rpm, all other noise tests are about 5.5krpm, just pull the clutch in a bit to get the quiet spot to stop the clutch rattle
If it’s 98dB static then you’d be pushing it with Termis. Standard pipes would be ok though...probably.
I've got 50mm Termis, I can't say it really sounds any louder than with the 45mm Termis that I originally had. The box they came in has '102db' written on it (don't know if that's normal?) and an iphone app confirms that to be about right. I doubt you'd get under 100db with any aftermarket cans...
