If I grab the rear shock by the cylinder I can rotate it about 5-10 degrees on my 848 Evo. It's very loose and wobbly. I had two chaps look at it while I was out today and they didn't think it was normal but couldn't say for sure (non ducati riders). How much free play is normal?
Thanks for the reply. From what I can see the top is attached with a pin that passes through the top of the shock mounting and the 'forks' that the shock is attached to. i don't see a spherical joint up there (i see the one at the bottom of some kind of linking arm) There is a gap between the two forks and the shock mounting and that,s where the free play is. Looks like there should be a washer or bush there? Sorry if this makes no sense, not sure of the correct description.
