Howdo!!! Good to see a new forum excellent!! I'm a Submariner by trade with a 1994 Superlight (Water-cooled) that I have owned for 12years and can't stop modifying Also have a GSXR1000K5 that I use to get to work on (Superlight is as quick if not quicker up to a certain speed my lud!!) Based in Cornwall land of the pastie! Cheers Pablo
Howdo Steve! How's it going? All good I hope. Here's a few (Old) pics of the bike. And list of a few things done: 1098 re-valved forks. 1098 Carbon front mudguard. Brembo Radial Calipers. Pro-mach adjustable yokes. Brembo master cylinders. BST's. ETi fuel cell. Ti front spindle. ST3 Dash. Carbon dash inserts. Mocol oil cooler in Headlight fairing. Radiator res in Headlight fairing. Moto Science mirrors. DP Carbon nose cone. Speedy moto 53mm clipons. Hel Brake lines. Samco hoses. ST3 Motor - Pistal pistons, gas flowed n blue printed, light weight flywheel. 1 Off Magnecor HT Leads. 1 Off Carbon belt covers. 1 Off Pro-alloy rad. PCIII Altered Silmotor full system Carbon seat unit (Breather unit). Corse reed valve. STM Crankcase breather. 12mm Ti engine bolts. Extended Ohlins rear shock. Tec-moto alloy sprocket cover. Modified ST3 loom. Ballistic 12cell battery. 1 Off MWR air filter. And a few other bit n bobs Cheers Pablo
Pablo. I would like to have your bike on www.ducati900sl.com if you wouldn't mind? As this is something special. I am good thanks. Steve.
