Hi I am looking at getting an exhaust system for my hypermotard 796 2012. I want the twin slip on that comes from under the seat. What one gives best noise and performance? Cheers Ryan
Without doubt the Zard Penta, but then I am just a little bit bias To complete the job you'll need a Leo Vince De-cat pipe then get the ECU remapped, it'll make it sound sweet, give you better torgue & power, it'll run soooooooo much smoother and use less fuel, sorted.
I found every after market exhaust was still too long so I chopped my standard one. Chopped exhaust | Ducati Forum
I heard the Zard were good. It's just why would it be bad for the bike to fit the zard with no adjustments to the ECU? Where is best place to get the zard exhaust and does anyone kno of a second hand set. Cheers
Ive got a catless MIVV system and single 70mm rear box christ makes ones ears bleed ... or is that the open 100mm trumpets with rather large K&N filters :smiley:
