No clutch pressure when pulling on lever. Changed fluid and bled the system. Still no good. I measured the distance the clutch rod was protruding outside the casing and it's about 35mm. Just seems the slave cylinder it's pushing the rod. Tired another slave and same problem. Rod seems pretty solid when you try and push it in further. Any ideas??
Daft question, but have you checked the other end of the rod (pressure plate side) to see what’s going on?
