So I mounted RCS corsa corta brake master cylinder on my 2011 multi and I ran into some problems. I disconnected my right blinker and removed the handguard because it is impossible to mount it together with the master cylinder. I dremeled the handguard within an inch of it's life but it wouldn't fit,the bleed nipple from the MC is in the way. Is it possible that some hypermotard handguards with blinkers would fit over the master cylinder? Are there any alternatives to mount some front blinkers on this bike which connect to the OEM connectors and are not in the handguards? I can think of buying some mirrors with inbuilt indicators but I don't know which ones. The bike looks wonky now because I can't remove the left handguard/blinker because there is no way to mount the clutch fluid reservoir then. Although i have ordered the hypermotard clutch master reservoir bracket which should fit.
