Hyperstrada 821 Engine Modes - Sport / Touring Explanation
Discussion in 'Newbies Hangout' started by Coolhands, Jun 1, 2018.
  1. I’ve read other threads but can’t find the answer. If I edit the riding mode in Touring to be the same engine power as Sport, are both maps then the same? (In default Touring is medium instead of high, whereas Sport is high).
    Or does the touring mode still have a different application of the throttle even if you have both modes set to high?
    2015 821 hyperstrada
  2. hi there Welcome. Head over to the Newbies hangout and introduce yourself.
    About your question, I have a '15 Hyper as well. The manual is not clear to me but i believe that if you make all the settings the same the the two modes are the same, I don't think there are two maps attached to the name, if you understand what I mean.
    I run mine in sport mode permanently unless I get caught in the rain then I switch to touring if things get iffy.
    Maybe someone else will chip in.
  3. thread moved and welcome Dave
  4. its chris, but cheers ;)
  5. Of course it is, Dave :)
  6. Welcome to the forum. :)
