1000 Idle Problem Slow Turn Over After Running
Discussion in 'Multistrada' started by Peter Rothwell, Feb 18, 2018.
  1. Hi guys and girls I purchased a 2006 Multistrada 1000ds as a non runner from a dealer who couldn't get it running, after new battery, plugs, and a lot of cleaning up of electrical contacts the bike starts and rev's but it refuses to Idle, carbs are balanced, I turned the idle up and slowly tried to reduce the idle but it just cuts out once I reduce the Idle. The other thing I noticed is that if the bike been running for say 20mins the re-start turn over is very slow in fact the battery has to be fully charged, I'm not sure if I need to reset the TPS (throttle positon sensor) anyone got any Idea's
  2. Welcome to the forum :cool:
  3. Sure someone will be along shortly, good luck
  4. could be many things but you are right in that TPS reset/check could help. A general tune would probably find the problem involving air bleeds, TPS, throttle body balance plus stepper motor function. Have you got std exhaust/air filter and have you had any fault codes come up?
  5. no codes showing but the bike seems to rev up cleanly and I can hold the throttle and control tick over just wondering if any one else has had the similar problem, its a std exhaust and air filter.
  6. you can raise idle with the adjustable throttle stop on R/H side of bike. It's hard to get to with 'glove compartment' side panel in place but not impossible. it's M2 allen key I think. This is a crude solution as stepper motor and air bleeds are supposed to ensure correct idle normally but it will probably solve your idle problem once you've started it.
  7. Carbs? On a 2006 bike? Are you sure?
  8. Thanks tried that one, it will set at high rev but as you wined it down it will cut out again, I thought it would be an imbalance on the carbs but they are both pulling the same, I think I'm going to investigate a bit more.
  9. as said, a full tune would be a good start, you can find all details here under 'Aircooled' Forum :- http://www.multistrada.net/forum/lo...&start=0&sid=0c9567fbac430a741096c124c2ffae1f
    btw, you know it's injected Peter?
  10. yep
  11. but just to avoid confusion for anyone reading - injectors and not carburetors/carbs.
  12. Welcome, I will not be spamming the forum map at you!
    • WTF WTF x 1
  13. Thread moved
