Ignition only turns on sometimes
Discussion in 'Supersport (1974-2007)' started by Danielmurphy90, Jul 25, 2013.
  1. Hi i have replace my battery and the ignition will only turn on if you move the negative going to the frame I've replace the wire and checked the fuses and still no joy please help
  2. Sounds like you may have a loose connection. Make sure the connection on the battery terminal is nice and clean and tight. Also at the point where the cable is connected tpo the frame.
    clean everything up at the frame point and make sure everything is secure.
    This is a great place to get help and someone will be able to share their knowledge with you outside of my limited help
