indicator switch gear problem
Discussion in 'Multistrada' started by iansbike, Sep 30, 2012.
  1. Has anybody had a problem with the indicator switch gear.
    when pushing the button for the right hand indicator it does not always work first time
    the left hand one works 1st time every time pushed.
    The only way i can be sure the dodgy one will work is to hold it on for a second or so.
    This is a intermitent fault as sometimes it works ok and typically when its been in for
    service or other work it always works fine 1st time.
  2. Try to give it a proper handful of WD-40, to remove water and also same with contact cleaner.
  3. Hi Andy i have tried the WD40 but its not really made a lot of difference but i will get some contact cleaner to see if it helps thanks for the advice.
  4. Talk to your dealer. My MY10 has exactly the same thing, although it's behaving itself at the moment. Ducati are replacing the left hand side switchgear.
  5. Oh...I should say, my problem is with the switchgear not working every time, rather than the indicator going off. You'll press a button, say to change the odometer, and it will sometimes not work.
