All, I fitted a new tail tidy and checked the indicators and they worked fine. Now the rear indicators seem to have swapped, the front ones are fine but the rear ones will flash left when I indicate right and vice versa. Any ideas?
Yeah - but they worked correctly for a couple of weeks - I just don't understand what has changed - I jet-washed the bike, so perhaps that has done it - but for it to suddely swap from working in the right way has ne scratching my head!
Are you sure they were working correctly for a couple of weeks? if you are then check the connectors for water from the jet wash
So when you washed it what did you use.....fairy liquid or Johnsons no tears shampoo and did you use sheep skin mitt ? or brillo pad to get the flies off ?
I would advise that when you wipe the bike down. to get all the grit and grime off. Use a very fine sand paper on all the body work. I have also heard that adding red bull to the petrol tank is also great, I mean look at the REd Bull F1 cars, they are winning very easily.
