Great instructions… They do not seem to match with the bolts provided… The instructions say to use 2 20mm bolts to fix the rearsets to the hanger. The pack for each side has only 1 20mm bolt… should I use the factory ones? There’s a bit that looks like a washer that is shown to go inside the cover of the brake master cylinder on instructions for different rearsets - this part is included in mine BUT the instructions simply say to remove the cover… and bin it? Truly awful instructions! Any help and tips would be appreciated as I’m trying to finish the job now.
Done. Hopefully correct… seems to be working as far as I can tell but I’ll test tomorrow. Mine actually didn’t have the cover on that it said to remove, I guess because I had the Rizoma rearsets from factory.
Probably. Quite a few bolts that weren’t required. I would usually worry when I have parts left over but it’s definitely done correctly… The part that screws into the quickshift rod was too long so I used the original. Not as plug and play as Gilles seems to be. There was quite a bit of guesswork involved and the brake light switch they provide has a cable that is a bit longer than necessary. Much less play in the levers now though and the foot pegs are a bit wider.
