Hi I have a problem with two bikes 900ss & st4s turn the key on spins over no start , turn on off till I hear fuel pump run then it starts right away. has any one had this problem sounds like relay to me. thanks all.
Yes, it does sound like your fuel pump relay. They are only a mechanical switch so likely to wear out and get sticky over time. Pull it out, take it to your local car parts place and they'll find you a replacement for about a fiver.
