Issues Fitting Evotech Usb Phone Cable To Monster 937
Discussion in 'Technical Help' started by Howard Kingsnorth, Oct 19, 2024.
  1. There are 2 choices: 1st is connect direct to battery and have the USB live all the time or, 2nd: connect white wire to the Key acc. so that it turns off. I cannot see where the white acc wire connects near the battery . . does anyone have experience of where this is?
  2. Always best to go with a switched live. Accessories such as this will likely have a small parasitic draw on your battery when the bike isn't running. I don't know the Monster but is there not an accessory socket under the seat that you can tap into the back of? Or even a sat nav connection up near the headstock?
  3. The USB socket in the tray under the rider’s seat is pretty useless. You could use the plug from that to give you a switched live. Andy
