Hi All, Acquired a 1098 lump for my 748R/1098 project. The seller said it had a JHP slipper fitted. The pressure plate has seen better days so I want to get a replacement. From photos JHP confirmed it is one of theirs but aren't being forth coming with a replacement. I believe the JHP unit to be a Bucci copy and in turn Bucci make the DP unit. I figure the pressure plates should be compatible, anyone confirm this? If so where can I get one! Cheers DM
What does it look like Danger Mouse? Is it a 4 spring unit or 6 ? I keep alloy pressure plates from CNC Racing in stock.......
Hi nog, It is a 6 spring unit. I suppose the important features are the spring pockets are deeper than a normal plate. They also protrude behind the pressure face. Do you think you might have something suitable??
