Mine came with Innovv K3 dual fitted. The front one was fitted in the centre under the nose - there’s a longer Allen bolt there which held it. The rear one was mounted to one of the bolts that hold the top box rack (I assume the bolt is there (or a hole) if you don’t have the rack. It looks like the K5 cameras are similar, so hopefully this helps?! Thanks, Ben
