Hi all, I need your help, DUCATI 749s 2003, termi slip-on with that ECU I think, if not standard ECU, I have lost both black keys, I have one red key and a key card, here in Burnham on sea I'm getting a lot of umm yeah's, when asking for help so ive come to the best. Could anyone offer light on how to progress forward, Do I order 2 blank with transponder keys, take to local cutter with red key, get cut then go home and follow key function process in handbook, Or get I think ChrisW to remove immob and then possibly flash for termi slip-on if its not already then get 2 non transponder keys and then get cut from red key, I would prefer to keep immob Most easiest but cost efficient way please, bear in mind I cannot travel at the moment All replies with help I am truly grateful, cause I'm in the shit again!
if you have the red key you can reprogram the dash/ecu with new black keys buy the blanks on ebay key a local locksmith to cut them them follow the instructions to program the black keys or call a dealership with the code card (there should be a physical key code and the immobiliser code) and they may be able to order you an official set from ducati
