KMH to MPH help
Discussion in 'Multistrada' started by PlymouthBikers, Apr 14, 2013.
  1. HI Multi owners wonder if you can help me shed some light on this.
    I unplugged my battery to fit heated jacket witch all works just great.
    My issue is my bike has set its time and settings to Kilometers per hour... Help.
    Now i have ran through the bikes settings and changed the clock but cannot see where to
    change to MPH.
    Anyone come across this and managed to to overcome. And would love to share with me how..
    regards
    Biker Dave Plymouth.
  2. Hi assuming its a 1200?? With ignition off you hold in flash button and confirm button on left handlebar off memory and keep held whilst turning ignition on. Should then bring option up in circular window.
  3. This is an extract from teh manual.
    "Units of measurement modification
    This function allows you to change the units of measurement
    of the displayed values.
    In order to enter this menu it is necessary to start the vehicle
    by holding down contemporaneously both the flash button
    (13, fig. 5) and the reset button (14, fig. 5) for at least 3
    seconds.
    After entering this menu, ”UNITS” is displayed; to set the
    units of measurements press the reset button (14, fig. 5).
    The instrument panel displays the values that can be
    modified; use buttons (1, fig. 8) ”▲” and (2, fig. 8) ”▼” to
    select the value to modify and press the reset button (14, fig.
    5) again."
    or what Jase said.
  4. AH Great many thanks for you guys and your quick response, ill try during the week.
    Its a bummer trying to figure out my speed..
    lol.
    cheers.:tongue:
  5. Jesus.. What a palaver!
  6. Had I remembered the way Jase explained before I went back to the book, it wouldn't have come across so complicated. The benefit is if you go to Europe, you are not always trying to convert miles to kilometers in your head and believe me that's a blessing in some of the towns that had 25 kph speed limnits enforced by cameras. Andy
  7. Changing the units is a known issue and has been posted on this and the ms forum many times! I think it's either the manual is not very clear or because it's not on the usual menu on the left that's catching people out!
    It may be time Ducati changed something....I mean we can't all be this thick??? Well er???:rolleyes: Maybe some! :biggrin::eek:
