Can anyone tell me the length of 900SS forks when fitted the bike (I appreciate there will be a slight variation, depending on springs/weight etc. want to see how they compare against a set of 1098 forks) Also after the length of the rear shock (Bolt centre to bolt centre) Cheers Pablo
Multistrada(1000/1100 aircooled) legs are 790mm axle ctr to top cap. Longest showa's made. SSie are 60mm shorter. Monster/SScarb/ST/ are 90mm shorter.
900SS Showa adjustables on a 750 SS Carbed.....705mm centre of axle to u/s cap......on the sidestand. And the springs are linear (not progressive) @ .84kg / mm AL.
Cheers Gents, Imola is that total length? Or centre to centre? The reason I ask is I thought my Ohlins was extended (The body has been extended and the eye rod is the longer version) at those measurements mine's not that far of a standard I.E shock.
Pablo, Eye to eye centres mate. I found when racing the 600 365mm was good on the white power racing shock i used along with the Forks approx 20mm sticking out of the top yoke. Bit unstable over bumpy circuits down the straight but turned on a sixpence!
I have nearly 25mm through the top yoke.......it counteracts the slowness of the 70 profile front tyre.....a bit wobbly at moving off speed until I got used to it, and it is almost too quick in corners.... AL
