Anyone here using the Leo Vince de-cat for V4 MTS? I'm looking at different options for my Pikes Peak, I really can't be bothered to pay approx £3300.00 for a full system fitted. Leo Vince De-cat is around £480.00. My question is, anyone using a De-cat, what map are you using? Upmap do a map, I've got a T800 already and map costs around 169 euros. Looking at the map dyno graphs there is not a massive difference between this and the full system and I'll save over £2K! Anyone using a de-cat, which are you using and what map?
I've replied to your PM In addition to that, I see you've had the same thought about a T800 as me, I have one that I used on my 1299. According to Termi, once the T800 is used on a bike, it gets all there info from it and can't be used on another bike, I was a bit pi$$ed off to say the least.
Thx for the info, I wouldv'e though the T800 could be used again when you buy another map from the Upmap store?
I've heard good things about these guys. £1619.00 with link pipe and re-flash unit. Then every time you get an update and Ducati resets your ECU you can just re-install the up-map. Plenty of videos on you tube too if you look. https://shop.bhp-uk.net/collections...-peak-decat-link-pipe-ecu-flasher-combination
I've seen that system, imho it seems a bit expensive for a de-cat and map. May as well go the full way and get the Akra full system.
