1199 Loose Mirrors
Discussion in 'Panigale' started by SissyMc7, May 25, 2014.
  1. Any one had prob with mirror working loose at pivot ? Cant tighten them looks like warranty job or take them off .
  2. Just had a set replaced under warranty. Fixings to fairing were tight, but pivot was starting to get loose. Rear view is now much better, without vibration in mirror.
  3. mines going in on thurs warranty job sissy cant tighten them mine also fold in at speed ,lol self streamlining bike
  4. A cant see much anyway prob just take m off
  5. that looks good for tomoro cause im blind as a bat as well ,
  6. Bit of a bump here.
    The right side mirror stalk is loose. The bolts under the screen are ok that hold on mirror unit, but outer stalk is loose.
    Is this a warranty job or is there a way to tighten the stalk ?
    Tks.
  7. Mines gone into hyside today for a load of work. The mirrors are shit anyway (and loose) so im replacing mine with those design corse blanking indicators. Will let you know how i find them (i know some people cant ride without mirrors but im not one of them).
  8. I had one replaced, bike was out of warranty.
  9. My right hand one is doing it but out of warranty and they won't move on it
    How did you get them to sort it?
  10. Just rang up and said its lose, i fitted it myself rather then took it in. Just swapped it
  11. Hi
    I have just had same problem
    I fixed it for virtually no money
    Take a very small black cable tie
    Push /place the thin end into and down the gap in the loose pivot section
    Take a very small flathead screwdriver ,and push cable tie into gap
    Then cut flush the remainder
    Basically I wedged a cable tie in gab
    No more wobble s and you can't see anything (unless you get real close
    Regards
    Simon
  12. did you just call your local dealer - or Ducati UK if there is such thing???
