Took the rear wheel off my 97 900ss today to replace the tyre. Both wheel bearings fell out as I cleaned the wheel, obviously not good. I've refitted using bearing and thread lock but not optimistic. Do I have any options short of replacing the wheel? Brian
Thread lock should do the job. There is a specific bearing glue but its probably the same but different. Failing that a few small spots of supaglue. Degrease and clean first.
loctite make a product specifically for this also a few centre punch marks done evenly around the circumfernece of the bearing housing will help take up any slack other options machining out housing to take a different bearing / fit a press fit sleeve into machined out housing - but a good second hand wheel on fleabay is possibly cheaper than either of these two options
just how loose were the bearings when you put them back in and are there signs of them turning much in their housings or is bearing surface on wheel smooth and virgin like? If you've caught them early or they've just stayed put despite being slightly loose then as above re:bearing fit loctite.
You can use Loctite Bearing Fit, which is a good solution. Center punching only creates high spots for the bearing to seat onto, so the bearing outer race will only be transfering the load onto the high spots and will soon fret the pop marks away. This is ok for a bodge/temp solution. There is usually not enough material on a wheel to re-sleeve it. As said, a replacement wheel is the safest option.
You may be able to get a small jobbing machine shop to bore them out and fit a steel sleeve and then bore that out to the bearing size I do that to the aircraft wheels when the bearings spin in the wheel hubs.
Loctite 638 or 641 should do it........I would favour 638 because it takes a much higher temperature to 'melt' it, but you have to exclude the air to get it go off......Lots of sticky tape over the bearing and hub should do it. AL.
With the weather we have had and no guarage I've only just had the chance to take the wheel off after a 50 mile run including some twisties. The bearingloc seems to have done the trick. New tyre to go on next weekend. Thanks for the responses. Brian
Lucky bugger removing bearings from my one is a job of it's own. Then again I had rims powder coated.
