M900 Belt change - any hints please?
Discussion in 'Ducati General Discussion' started by Ian, Jun 12, 2013.
  1. I'm about to change the belts on a 900 Monster. Does anybody have hints or tips please? For example, I seem to recall a little discussion over the correct tension, is there an easy way / hard way? I've seen a video clip or two on YouTube, admittedly on an engine on a bench, it seems reasonably do-able!
    Thanks,
    Ian.
  2. I've done both my M600 & M900. It's quite a straight forward job, belt tension should be roughly a 45 degree twist on the long run between pulleys.
