Yep I think you are right, I don't see it though on the melco diag read out I now think the software # is just the operating system
Yep, the Calibration code is the actual fuel mapping loaded into the ECU, but, wouldn’t yours say ‘Racing’ on start up if it had the DP map? I know my 1100S did but admittedly that’s an earlier iteration.
Hi, yes it does say race and it has been remapped but what I am trying to work out if it has the DP map or the Termi Up Map and I believe both display Race, the perceived advantage of the Termi map is there are 5 versions to go at.
This was finally solved, the DP map uses the lambda sensors meaning if you unplug them the engine warning light will appear whereas I believe this is not the case with the Termi map. Fitting 02 eliminators with the DP map improves the low speed fueling.
