Mikuni Carb Jet Needle
Discussion in 'Supersport (1974-2007)' started by Stav, Nov 3, 2015.
  1. Anybody got any experience of using a Keyster Carb rebuild kit on the 38mm Mikuni carbs on a 1994 900ss?
    Ive just stripped cleaned and rebuild my carbs with two of these Kits
    K-1336DK Carb Repair Kits (one for each carb)
    Motorcycle repair kits
    Ducati 900SS Supersport 1991-1997
    All looks ok except for the aluminium jet needle, the original one tapers to a point, the one in this kit has much less of a taper ( same length though )
    Its going to be a couple of months before I get it all backtogether to find out how she runs, as ive got the engine out,
    Cheers
  2. Not Ducati but the principle will be the same
    I have just fitted a much larger engine in an St 70 fitted a 28mm Carb to it and then spent hours tuning it with numerous mains , pilots and needles
    I have a link about tuning carbs and what effect the different parts have.
    You can get all your needles jets etc from a company called Allens near Nottingham ,Bingham I think to be exact
  3. Take a photo of the needle and post here........There's plenty on Mikiuni and Dynojet stuff on the SS forum if you search.....the OEM Mikuni needle looks like a nail and there will be a square logo and a size on it............Dynojet there is no logo or size.......
    .........I can only guess what your needle will be like by comparing with either of the above............and what the main jet is.....
