Mikuni Carbs set up
Discussion in 'Supersport (1974-2007)' started by Imola, Feb 13, 2013.
  1. I have worked on them before and tried lots of different set ups and aftermarket parts etc
    Just wondering if any new tips on these not very good carbs to get them set up to work.
    Cheers
  2. new emulsion tubes
  3. Fuel height / float level.......fairly critical.............check what yours are set at and if relatively equal, try them like that before you adjust them......
    It is debateable which side of the floats you should measure.....some say the diamond shape one, some say the rectangular one.
    The default is approx 14mm. 13mm richens and 15mm weakens.
    As far as I can see, measuring the rectangular float is the right one to use.
    Also check the main and air cut-off diaphragms......although they might look OK, they can get porous.
    If Dynojetted, make sure the needle is correct size, and the main jets, of course.
    Getting the balance right can be a s*d........use a bit of thin fuse wire as a feeler gauge between the butterfly and throat when the carbs are shut, so the initial opening of the butterflies are equal.
    Pull the tiny filter out of the fule inlet tee-piece between the two carbs and make sure it is clean.
    Mount the carbs a vice at the correct angle, fill a small squeezy bottle with petrol and add a hose so you can fill the carbs........wait to see if they leak........then change the hose for a footpump with a gauge......apply pressure and see at what pressure the float needles give way.......less than 10-12psi, they are likely to leak.........if they leak, change the float assemblies (they come with the float needles).
    Any more?
    AL
    #3 Ghost Rider, Feb 14, 2013
  4. Cheers Al and steve.
    This thread will benefit all.
    whats the usual main jet size used in a dyna jet kit ?
  5. Mine are in bits and i found..
    Main jet o rings perished (standard size)
    DJ tapered needles and springs.
    14mm float hight
  6. You have an email with some DJ instructions and specifications.......Stage 1 & 2......sse what you think.
    PS.....I have a pair of old carbs for a 900 which had a DJ kit.....the main jets were 155 DJ type.
    AL.
  7. Cheers Al
    Found gaskets etc in my shed..
    Just need 2 x main jet o rings.
    anyone have the o ring size ?
  8. Imola,
    Found 1st list below on Sudco Site but main jet o ring does not seem to be on and there are a few number I have not seen before.
    2nd list is my list taken from Allens with a few prices I got & green is just the bits I wanted.
    I have a new ones from both Allens & Litetek that I have not fitted and the best I can measure for Main Jet o ring is below:
    (But probably better buying the right ones rather than trying to match the readily available ones which I know cost about 3p each).
    Allens - 1.00/1.05mm thk 6.3/6.4 od (it was easier to measure od)
    Litetek - 1.10/1.15mm thk 6.5/6.6 od
    SUDCO Mikuni Carburetor O-Rings
    Genuine OEM MIKUNI carburetor o-rings. Made in Japan.
    Order No. Description 007-945
    SUDCO Mikuni Carburetor Dealer O-Ring Kit
    includes qt5 each part number listed below.
    (total qt 75 o-rings and plastic storage box)
    Sudco Order / Mikuni No. Reference / O-Ring Size Inside x Description Thickness
    002-212 BV32/04 - 3.55 I.D. x 1.78mm
    002-531 VM28/254 Drain Plug 19.50 I.D. x 1.52mm
    002-602 BNO42/64 - 17.50 I.D. x 1.52mm
    002-617 BV30/40 - 8.70 I.D. x 1.95mm
    002-672 VM18/249 Starter Plunger 8.50 I.D. x 1.55mm
    002-676 VM14/75 Pilot Air Screw 2.50 I.D. x 1.55mm
    002-709 KV/10 Fuel Joint & Needle Valve 7.75 I.D. x 1.53mm
    002-825 VM26/227 - 19.60 I.D. x 2.43mm
    002-838 VM24/559 Needle Valve 6.70 I.D. x 1.35mm
    002-858 N133.037 Pilot Air Screw 2.70 I.D. x 1.13mm
    007-160 N138.198 Starter/Choke 10.25 I.D. x 1.35mm
    007-163 N124.063 - 1.80 I.D. x 1.15mm
    007-182 616-23002 Fuel Joint 6.25 I.D. x 1.83mm
    007-188 B30/205 - 3.05 I.D. x 1.35mm
    007-470 616-33003 Needle Valve 8.47 I.D. x 1.53mm
    [TABLE]
    [TR]
    [TD]MIKUNI BDST 38 B67 CARBURETOR PARTS LIST[/TD]
    [TD][/TD]
    [TD="width: 50"][/TD]
    [TD="width: 64"][/TD]
    [TD="width: 20"][/TD]
    [/TR]
    [TR]
    [TD]
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]DESCRIPTION[/TD]
    [TD]PART NO.[/TD]
    [TD]QTY[/TD]
    [TD]£[/TD]
    [TD]Total[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]
    [/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Bracket/starter plunger[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/175[/TD]
    [TD="bgcolor: #00FF00"]2[/TD]
    [TD="bgcolor: #00FF00"]2.3[/TD]
    [TD="bgcolor: #00FF00"]4.6[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Clip/jet needle[/TD]
    [TD]TM32/90[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Cover/air cut valve[/TD]
    [TD]MRT-H/250[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Diaphragm/air cut valve[/TD]
    [TD]MRT-H/005[/TD]
    [TD]0[/TD]
    [TD]15.69[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Diaphragm/throttle valve[/TD]
    [TD]MRT-H/072[/TD]
    [TD]0[/TD]
    [TD]15.25[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Drain screw/float bowl[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/190[/TD]
    [TD="bgcolor: #00FF00"]1.58[/TD]
    [TD="bgcolor: #00FF00"]3.16[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Float bowl[/TD]
    [TD]MRT-H/090[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Float including needle valve assy[/TD]
    [TD]N213010-17[/TD]
    [TD]0[/TD]
    [TD]19.31[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Fuel inlet T Piece[/TD]
    [TD]MRT-H/185[/TD]
    [TD]0[/TD]
    [TD]6.52[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Jet block[/TD]
    [TD]MRT-H/160[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Jet needle[/TD]
    [TD]J8-5C19[/TD]
    [TD]0[/TD]
    [TD]7[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Main jet[/TD]
    [TD]N208099-size[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Needle jet[/TD]
    [TD]611 (750) 750-Y-6[/TD]
    [TD]0[/TD]
    [TD]
    [/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Needle jet[/TD]
    [TD]611 (900) 900-Y-2[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]O-ring/main[/TD]
    [TD="bgcolor: #00FF00"]616-12001[/TD]
    [TD="bgcolor: #00FF00"]1.98[/TD]
    [TD="bgcolor: #00FF00"]3.96[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]O-ring/needle valve assy[/TD]
    [TD="bgcolor: #00FF00"]616-23003[/TD]
    [TD="bgcolor: #00FF00"]2.46[/TD]
    [TD="bgcolor: #00FF00"]4.92[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]O-ring/pilot mixture screw[/TD]
    [TD="bgcolor: #00FF00"]N133037[/TD]
    [TD="bgcolor: #00FF00"]1.53[/TD]
    [TD="bgcolor: #00FF00"]3.06[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]O-ring/throttle valve guide[/TD]
    [TD="bgcolor: #00FF00"]N138198[/TD]
    [TD="bgcolor: #00FF00"]0.89[/TD]
    [TD="bgcolor: #00FF00"]1.78[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]O-ring/top cover[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/106[/TD]
    [TD="bgcolor: #00FF00"]1.74[/TD]
    [TD="bgcolor: #00FF00"]3.48[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Pilot jet[/TD]
    [TD]N151067-size[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Pilot mixture screw[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/172[/TD]
    [TD="bgcolor: #00FF00"]5.52[/TD]
    [TD="bgcolor: #00FF00"]11.04[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Plastic washer/jet needle[/TD]
    [TD]MRT-H/118[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Retaining plate/main jet[/TD]
    [TD]MRT-H/123[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Rubber seal/starter plunger[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/163[/TD]
    [TD="bgcolor: #00FF00"]2.47[/TD]
    [TD="bgcolor: #00FF00"]4.94[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Screw/jet block[/TD]
    [TD]MRT-H/119[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Seal/float bowl[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/161[/TD]
    [TD="bgcolor: #00FF00"]4.41[/TD]
    [TD="bgcolor: #00FF00"]8.82[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Seal/fuel inlet[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/046[/TD]
    [TD="bgcolor: #00FF00"]3.62[/TD]
    [TD="bgcolor: #00FF00"]7.24[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Seal/jet block[/TD]
    [TD="bgcolor: #00FF00"]MRT-H/162[/TD]
    [TD="bgcolor: #00FF00"]1.88[/TD]
    [TD="bgcolor: #00FF00"]3.76[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Sealing plate/starter plunger[/TD]
    [TD]MRT-H/177[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Spring/pilot mixture screw[/TD]
    [TD="bgcolor: #00FF00"]N133206[/TD]
    [TD="bgcolor: #00FF00"]1.28[/TD]
    [TD="bgcolor: #00FF00"]2.56[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Spring/throttle valve[/TD]
    [TD]MRT-H/157[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Starter jet[/TD]
    [TD]N100604-size[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Starter plunger[/TD]
    [TD]MRT-H/176[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Throttle valve guide[/TD]
    [TD]MRT-H/126[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Throttle valve including diaphragm[/TD]
    [TD]MRT-H/151[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD]Top cover/throttle valve[/TD]
    [TD]MRT-H/134[/TD]
    [TD]0[/TD]
    [TD][/TD]
    [TD]0[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #00FF00"]Washer/pilot mixture screw[/TD]
    [TD="bgcolor: #00FF00"]VM12/33[/TD]
    [TD="bgcolor: #00FF00"]1.37[/TD]
    [TD="bgcolor: #00FF00"]2.74[/TD]
    [TD][/TD]
    [/TR]
    [/TABLE]
    Please double check part numbers if your going to spend any dosh.
    Cheers Gaz.
  9. Cheers Gaz :upyeah:
