Mikuni service kit
Discussion in 'Supersport (1974-2007)' started by ush1000, Sep 28, 2013.
  1. Can you get a kit of parts, o rings etc to service the 38mm carbs for a 900SS? I could always get bits for Dellorto's for my Guzzis but internet search so far has come up short!
  2. Try NRP Carbs site. They have most parts for our carbs.
  3. Ush1000
    In the absence of AL and seeing as I brought it up (sorry if you don't get it, reference to a previous post) see following posts
    Carby Strip Down
    Mikuni Carbs set up
    I got my stuff from Allens Performance and I got a set of Viton stuff from Litetek
    I have some pictures so if you want some emailing - PM me.
    Cheers Gaz
  4. Gilps
    Beat me by 3 minutes - I was watching strictly
  5. If you want a basic service kit for the 38 BDST carbs, try searching for the Yamaha TDM 850 service kit......
    If you want more than that, like float needles, diaphragms etc, then generally it would be a call to Allens.
    AL
  6. +1 on Allens, very helpful and always had in stock what I wanted also helps that they're local to me.
  7. Thanks for very useful replies. I have bought a second hand pair of carbs from ebay, hope to make a good set using parts from both.
    Andrew
  8. The kits are on eBay, look under TDM 850, include every thing, even the tubes and needles for less than £50. Can't be bad (£50 is per side). Looked at them the other day myself.
