Mirror Vibration
Discussion in 'Supersport (1974-2007)' started by ck_uk, Jul 18, 2015.
  1. Does anyone use a bracing mechanism of any kind on the front fairing, to reduce the vibration at some speeds which puts the mirrors into chocolate teapot mode?
    YellowDuc posed this question before, the answer to which made me chuckle:
    Mirror vibration at low speed | Ducati Forum
    Could a bar-end mirror solution such as this be used instead, not sure whether legal in the UK tho..
    http://nydesmo.com/images/IMG_0847.JPG
  2. Bar end mirrors are legal in the UK........and someone on this forum braced the 'subframe' mirror stalks.......
    Mine don't vibrate so have a real good look at your fairing fixings and make sure they are tight.
    Failing everything else, I wonder if you stuck a vibrator up your bum the frequency would be the same as the mirrors.;)
