848 Missing Keys
Discussion in '848 / 1098 / 1198' started by Hoggyjay, May 25, 2014.
  1. I have the chance of buying an 848 EVO that has been classed as a Cat D. The bike will be used on the track. The biggest hurdle is that there are no keys with the bike. The dealer is very reputable and I have no worries about its status.
    I would be prepared to change to a race ECU if this would cure the problem. Any advice?
  2. You will need to get the clocks decoded. Contact Scorpio Electronics - Contact. As the immo on this bike is in the clocks only.
    The ECU is uncoded.
  3. Cheers I'll drop them a line.
  4. Reply as below - Still need advice
    Hi Iain
    We can't help with regard to the recoding of your clocks as we can only clone a faulty speedo to a good working one for these bikes at the moment.
    regards
    mark
  5. Have you checked down the sofa for the key?
  6. Cheers Mary,
    I'll track down the previous owner and ask if I can check his furniture. I'll take advice from any corner of the globe. From the looks of things I'm gong to let the bike pass. A 2008 road bike conversion will be less hassle in the long run.
