Lovely yellow unmarked seat taken from a 2005 749s ( mono ) All paint stickers / decals are spot on. One nut on the underside could do with a spot of glue to stop it rotating. Offers around £150 plus post.
I would be interested in this if you can confirm that it is an easy fit onto a 07 plate 749 ? I've seen one like this and I would of had to change the tail end frame part of my two seater. What part of the country are you from ? Guvs.
The mono and bip subframes are different Guvs as I found out last year when I did this mod to my bip. This mono seat unit will only fit a mono(alloy) subframe but it's worth doing as the weight saving is quite something.
My advice would be to snap this up quick and try and locate a mono subframe at a later date. I paid a lot more for mine and it needed painting too.
