Monster 1200/821 Headlight Disassembly
Discussion in 'Monster' started by Pratz, Dec 10, 2014.
  1. Hi,
    I'm a 821 dark owner and bought recently some Duc performance led blinkers. At rear with evotech tail tidy was simple, fast and clean to do, but at front how can I remove the headlight ? At the owners manual it only show how to disassemble OEM blinkers o_O , and doesn't have any headlight reference.
    Thnks
  2. Hi yer, remove the LCD screen , two bolts one each side , unplug it.
    Each side of the bottom yoke is a 10mm nut , un do those, & then the head light is only held in place by two location pins on top of the head light, gently pull up on the head light & it will come free, I covered the front mud guard with a towel so nothing damaged the guard.
    The outer metal cover is held in with four small torque screws , once un done & indicators un plugged the head light will come free. I replaced my indi lense's with smoked ones from R projects. Good luck & go easy.
    #2 Morecambedesmo, Dec 11, 2014
  3. Worked like you said! Thanks ...and Duc performance LED blinkers are awesome!
