Annoyingly my monster 620 2002 has the temperature unit set as fahrenheit. Can anyone remember how to change it to degrees. I can change the time settings etc but no cigar on this.
OK , I cracked this one myself as follows. With the key off hold down the two buttons and turn the key on . If the clock is showing Fahrenheit it will flash USA.Press the left button to change to EU. The next tricky bit is to get it to save which requires holding the two buttons down at the same time until it shows "off" . If you do it in EU mode it switches to USA mode (because you are pressing left) so I did it in USA mode and this saved it in EU mode. Sort of makes sense. If you now switch off then on you should see degrees as the temperature unit.
