Hi, I would like to change by myself the chain from my Monster 695, but have some doubts that would like to share with you.... May I change only the chain (sprockets doesn’t look bad ?)... or better change the complete kit including sprockets ? Recommended/Better to mount a 14 tooth front sprocket ? If install a 14 tooth front sprocket (...and 42 on the rear) will the chain scrape against the swingarm ? For the chain seems to be a good choice the DID 520XV2, but for the sprockets I’ve seen he brands JT and ESJOT... some suggestion ? Best regards
