Wanted early '96 600 (750/900?) rear damper in good condition. Mine has a corroded damper rod so MOT failure I think, not leaking though!
Be careful Pete...I had a Monster in for fettling over the winter and tho it looked solid, the damper rod snapped as I took off the swingarm............get a proper shock on there.....
Hi Pablo,Very kind of you but not sure as I dont know the dimensions of either! I will try and check the distance between the rod eyes and the width of the rod ends later today. The monster i have is an early one with the hoop and I believe the ST3 has a rod operated actuation system?
