1200 Enduro More Front End Clonk Diagnosis
Discussion in 'Multistrada' started by Edward Cunliffe, Jul 5, 2024.
  1. Just a thought (in diagnosing my front end clonk) does the Skyhook front suspension still function if the left hand fork leg is unplugged from the electrickery?
  2. No it won't, left leg will go solid. Pretty sure your suspension is topping out, if you unwind the preload all the way on the right leg, assuming you've adjusted this to your weight etc. I bet the noise reduces or disappears.
  3. Thanks, yes I have added preload, will try backing it off all the way.
