749 More Head Light Relay Related Questions ?
Discussion in '749 / 999' started by DeanF, Jan 3, 2015.
  1. Hello All.
    Following on from this thread.
    749 - Wire Identification Headlight Relay Plug ? | Ducati Forum
    If i put 12v to the Red/green wire on the headlight relay plug & switch the ignition on my dipped beam illuminates... So i definitely have a bit of tracing to do with this wire......
    Question is ? When your headlights are on & you switch to main beam does your dipped headlight go out ? Mine does, just curious if this is correct ...
    Cheers
    Dean
  2. Normal behaviour
  3. This is normal behaviour but can be modified by bridging two wires in the dip switch assembly.
    The dipped beam will then stay on along with the main beam, giving a better spread of light.
  4. Cheers Both.
    I thought it might be but you know how your truly not sure as its one of those things you never study until you have an issue :D
    Cheers
  5. Know its an old thread but in the aim of not hitting the hedge, which two wires do you joint to get dip and main at the same time.
    Cheers chaps
