Hi,Does anyone have or know where I can get one of the above to fit a 2000 748? it is the steel reversable paddock stand.Cheers
Hiya, What pin is this please? One of the clips holding the swingarm cups in? Can you post a pic of the other one at all? :smile:
Try Russ at www.ducatimondo.co.uk Top bloke and bound to be able to help. Have a look on the website, has loads of paddock stand pins, I think its 25mm for a 748/916.
Motrax went bust and there were loads of these stands being flogged off cheap without pins. Didn't someone establish that another brand fitted?
The pin for my 748 is tapered, withe 25mm bit doing the lifting. Will have to have a look at the axle, pretty sure its the same thickness all the way through.
