899 Mra Double Bubble
Discussion in 'Panigale' started by Richieb2240, Apr 23, 2016.
  1. Saw a nice 1199 with an MRA screen today in Bristol so I might replace my scratched one with this. Been looking online and in the pics they come with a beading on the top lip. Does anyone know if that's a separate item you can choose to fit or not? Not a fan of them. Thanks
  2. I'm considering one of these as well if anyone has any pics ?!
    The standard screen is shite and scratches very easily it would seem
  3. I had one for my S1000RR and the beading comes as standard, didn't expect to see it. You need it to finish it off, however turned out it was a very tight fit and didn't look that bad in the end....not sure how much this helps
  4. Weird how the one I saw today didn't have one. Damn it, should've collared the bloke
  5. I've just fitted a new Puig screen to my 1198 which I'm very happy with. I guess they will also do a screen for your bike too. Not the cheapest but the quality and fit of mine is excellent.
    Just though worth a mention as an alternative for you ;)
  6. I've an MRA screen on my 1299, no beading...looks the danglies.
    Easy fit...though nose fairing has to come off. Bit of a faff but worth it.
  7. So did it come with the beading and you chose not to fit it? What was it called? Double bubble, corsa etc? Cheers
  8. I have one on my 899. The beading comes in the packaging. I fitted it as I thought it looks unfinished with out it.
    I can take photos later if you want??
  9. That would be great! Thanks
  10. Hi Richie
    I was at the Italian show in Bristol on Saturday on my 1199 , so it might be mine you seen. The MRA Screen does come with a bead for the top lip I choose not to fit it as I don't like the clips on the ends, its a clear double bobble with blackout at the clocks and fits nice too. Took the whole fairing off to fit it because I wanted to do a proper clean and fit the Racebolt Ti bolts to the bike at the same time, hope this helps cheers
  11. Nice one James thanks.
    Our Lee, were you parked opposite the Desmo? If that's the case, it was your bike I saw. Is your screen as big as James's above?
  12. Hi Richie,
    Yeah that was my bike, I have taken a measurement from the front edge of the top yoke to the top of the screen (210mm). Sorry for the delay I've been working away, cheers.
