What is the 'optimum' running temperature for my Multistrada 1100s. I changed the oil and filter today and ran the engine up to 150c just to check for leaks. During normal riding around in Cornwall, the temp hovers around 70c - 80c I have read on other forums that some MTS riders close up a couple of the vents in front of the oil cooler in order that the oil runs hotter. Any advice please. Pete
My SS sits happily fully warmed at 105-110c? Have indeed taped up the front of my oil cooler in these cool climes at the mo, means a quicker warmup/engine gets up to temp for shortish trips? Long trips means the tape gets removed after warmup. Using proper foil heat-resistant ductape, almost a crude thermostat... :biggrin:
thats the favourite Pete during winter all 4 of mine blocked so it stays about 90C even in frosts......you don't get so much white emullsion(no not paint:wink in the oil then too
Yes that's why I'm asking cos before I did my oil change yesterday the window was white. I ran the bike up to 150c and it cleared. Just need to find some dense foam I can shape to fit.
Remove your oil filler plug when you get home, lets your crankcase breathe & you dont get so much condensation/emulsion in the cold/short trips? ** Put the plug in an aerosol lid on your fuel filler cap so you dont forget to refit it before you go out again!
